  • SN95 4.6L Mustang Tech
TPS part question
  • Thread starter Thread starter mat82284
  • Start date Start date Nov 6, 2006
M
mat82284
889
  • Nov 6, 2006
My car needs a new tps and my friend is going to get one from ford for me but they have to order one and it'll take a week. I went to kragen and they have one for 33 and i was wondering if anyone has tried one from them? or maybe autozone or napa auto parts? If so how much did it cost you and how well is it working compaired to the oem one?
here is the link to the kragen one
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=NIE&mfrpartnumber=FE4025&parttype=280&ptset=A
RandyStinchcomb
1,159
Randallstown, Md
Nov 7, 2006
  • Nov 7, 2006
as I keep preaching: DO NOT BUY AFTERMARKET ELECTRONICS FOR FORDS!! they do not work as good as the OEM. if you need a Ford one, we have in stock but my main question is "WHY" do you think you need one? the Modular TPS's used since @1994 have been absolutely "trouble free"
M
mat82284
889
  • Nov 7, 2006
The voltage on the tps is way off. It wont go above .17v and when its on wot it only goes to 1.17v max and that all. So somehow it became defective.
speedfreak98r
Banned
Jan 31, 2006
Houston Area
Nov 7, 2006
  • Nov 7, 2006
They are very sensitive..Make sure it is adjusted very carefully.
stangGT97
1,299
Boston area, MA
Nov 7, 2006
  • Nov 7, 2006
Randy, just a question for you pertaining to aftermarket electronics... what sort of problems could arise? I have a Wells IAC, and I think it might be the culprit of some of my part throttle drive quality issues but then again, I don't know much about how that system works.
To the original poster, the orientation of the TPS has a direct effect on its voltage readings. Make sure it is installed in the orientation it came in from the factory.
M
mat82284
889
  • Nov 7, 2006
yeah i tried i cant get it to read anything higher than 1v on wot and it should be near 5 or at 5v from what i hear. Also when i unplug the tps the idle doesnt move or change at all it acts the same way.
RandyStinchcomb
1,159
Randallstown, Md
Nov 7, 2006
  • Nov 7, 2006
well to the 1st poster, did you change thrttlbdy's or something?
now to the question of aftermarket vs OEM.
Ford designs a part to work wthin certian parameters, lets use A to D.
now the aftermarlet opens-up these parameters from, lets say A to G so they can get that 1 part to fit mulitple vehicles and now the computer see's different values from the aftermarket part then Ford ECM intended it to see
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Nov 8, 2006
  • Nov 8, 2006
Yeah it sounds like you have a RARE failed TPS, just install a new FORD one the same way the old one is in there and DO NOT try to adjust it to .99 at idle like you do on a EEC IV car like the old 5.0's the EEC V system uses the lowest TPS reading the PCM sees after each key cycle to use as the C/T voltage.. anything from .53-1.27 is ok for C/T as long as it's the lowest reading the PCM has seen that key cycle.
only other thing I would check first is to make sure you have the correct REF voltage, if you don't have 5v on the REF then that is your problem not the sensor. BTW it will run the same with the sensor unpluged at idle that is normal.
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Betty white budget build
  • Stevenmverrill
  • Jun 16, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2023
2Blue2
