  • 1994 - 1995 Specific Tech
TPS Question
  • Thread starter Thread starter rude_life
  • Start date Start date Jun 18, 2005
rude_life
372
  • Jun 18, 2005
Hey i know this is probably a stupid little newby question but please, enlighten me...What type of symptoms are typical of a bad Throttle Positioning Sensor?
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 18, 2005
  • Jun 18, 2005
Ummmmmmmmmmmmmm well i know when i replaced my T.B and didnt have the TPS set right it would idel at like 3,000 after driving it! So i would assume that if it's not working then you would idol weird if not high then to low? But i'm not 100% on this. I can go look today cause in the new direction's it tell's you to check the voltage between 2 wire's on the TPS to get it set right so you might be able to tell that way as well? All you need to do this is a volt meter and i'm preaty shure that a $10.00 one from anywhere will work? If you have one i think they want it set at .095? but let me check for shure and wich one's to check voltage between. peace
john
HISSIN50
34
129
Jun 18, 2005
  • Jun 18, 2005
Bad TPS will cause poor milage, bogging, surging, etc. Either the puter will zero out its baseline or it should toss a code.
Checking it cant hurt. Here is a link to help with checking it out:
http://www.muscularmustangs.com/tps.php
Good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 18, 2005
  • Jun 18, 2005
Yeah, just check your TPS voltage at closed throttle and WOT. Just turn the key to acc, backprobe the wires. Should be somewhere around closed = .90-1.1. WOT = ~4.66
Scott
HISSIN50
34
129
Jun 18, 2005
  • Jun 18, 2005
And one can watch the sweep from closed throttle to WOT (a VOM works best) to make sure there are no dead spots, which can create a hiccup.
Good luck.
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
R
TPS
  • Redguy69
  • May 5, 2025
1994 - 1995 Specific Tech May 5, 2025
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
MS cranking parameters
  • Mustang5L5
  • May 14, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum May 20, 2026
Mustang5L5
