tps question
I went out and checked my tps voltage because I got a code saying it was out of spec....and my voltage is at ~.67 or so.
what kind of symptoms would this cause because the voltage is supposed to be at .94 or so IIRC.
btw, this is a new tps.
When you put in that new TPS did you dissconnect the battery to reset the ECU because .67 shouldnt give you a problem. Anywhere below that is where I think you would have a problem. It should never be 0 or 5 thats when you get a CEL. *And of course too close to 0 or 5*
