tps sensor black ground wire
noslow1986
274
oswego Il
ok the back wire on the tps sensors must be bad cause i can only read volts if the one meter wire red is on green and black meter wire a ground bolt. it wont read on the black sensor wire cause i think i went to deep and broke the black wire on tps
Try Ohming out the black TPS wire. If the meter reads infinite/open, move upstream (away from the TPS and where you think you broke your wire) and see if it ohms out there. If so, repair the break. If not, you might have to do some wire chasing.
Good luck.
How it is supposed to work:
The black/white wire (pin 46) is signal ground for the computer. It provides a dedicated
ground for the EGR, Baro, ACT, ECT, & TPS sensors as well as the ground to put the
computer into self test mode. Since it is a dedicated ground, it passes through the computer
on its way to the computer main power ground that terminates at the battery pigtail ground.
It should read less than 1.5 ohms when measured from anyplace on the engine harness with
the battery pigtail ground as the other reference point for the ohmmeter probe. What sometimes
happens is that it gets jumpered to power which either burns up the wiring or burns the trace
off the pc board inside the computer. That trace connects pins 46 to pins 40 & 60. Only an
experienced electronics technician can open the computer up & repair the trace if it burns
up and creates an open circuit.
Some basic checks you can make to be sure that the sensor is getting ground:
Note that all resistance tests must be done with power off. Measuring resistance
with a circuit powered on will give false readings and possibly damage the meter.
Check the resistance between the black/white wire on the MAP/BARO sensor and then
the black/white wire on the EGR and the same wire on the TPS. It should be less than 1 ohm.
Next check the resistance between the black/white wire and the negative battery cable.
It should be less than 1.5 ohm.
The 10 pin salt & pepper shaker connector can also be a problem. The white connector has
a pin maked SIG-RTN that is the black/white wire ground for the sensors.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine
ok can i use the jumper wire method to test for codes. and could this or has this ever been done cut the old harness off and replace it with a 90 to 93 harness with out having to use the jumper wire. i tried using the tester to test for codes but the light goes really dim and i dont know why. is there a code tester i can that shows numbers rather then hearing beeps
The first post I made has most of the computer won't go into diagnostic mode test information.
Here is the rest of of it from start to finish. It is almost a complete duplicate of
the first post. To do the tests, you have to start at the beginning and work all
the way to the end. That way you know everything got tested correctly and
you know what is good and what isn't. Read it through carefully from start to finish
and do all the tests. That way you will find the problem and fix it easily.
Computer will not go into diagnostic mode
The STI (Self Test Input ) is jumpered to ground to put the computer into test mode. Jumpering
it to power can produce unknown results, including damage to the computer. The ohm test
simply verifies that there are no breaks in the wiring between the test connector and the computer input.
How to test the wiring :
With the power off, measure the resistance between the computer test ground
(black/white wire) on the self test connector and battery ground. You should see less than
1.5 ohms.
attachment.php
If that check fails, remove the passenger side kick panel and disconnect the computer
connector. There is a 10 MM bolt that holds it in place. Measure the resistance between
the black/white wire and pin 46: it should be less than 1.5 ohms. More that 1.5 ohms is a
wiring problem. If it reads 1.5 ohms or less, then the computer is suspect. On the
computer, measure the resistance between pin 46 and pins 40 & 60: it should be less than
1.5 ohms. More that that and the computer’s internal ground has failed, and the computer
needs to be replaced.
If the first ground check was good, there are other wires to check. Measure the
resistance between the STI computer self test connector (red/white wire) and pin 48 on
the computer main connector: it should be less than 1.5 ohms. More that 1.5 ohms is a
wiring problem
The following is a view from the computer side of the computer connector.
