  • SN95 4.6L Mustang Tech
TPS Sensor can't be removed!!!
  • Thread starter Thread starter 97gtconv.
  • Start date Start date May 7, 2006
97gtconv.
244
Lock Haven, PA
May 7, 2006
  • May 7, 2006
Alright, I bought a Granatelli plenum and a BBK 75mm throttle body to put on my stang. I however cannot get one of the screws out for the TPS sensor. I had to use a pair of vise grips just get the one out and that doesn't even work on the other one. It just keeps tearing it up more. Any idea's??? How much for a new TPS ??
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
May 7, 2006
  • May 7, 2006
I think new TPS is like 50bucks from advanced Auto. It wasn't that expensive
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 7, 2006
  • May 7, 2006
I took mine to work and had one of our mechanics take out the screw. Put the TB in a vise and used a screwdriver with a good bite. The locktite is what holds it in place and is why it is so hard to remove.
97gtconv.
244
Lock Haven, PA
May 7, 2006
  • May 7, 2006
what a pain in the a$$. why the hell did they put locktide on it??
mity2
Jul 24, 2003
2,872
StateCollege PA
May 7, 2006
  • May 7, 2006
because if TPS screw loosen, and TPS move, it'll do all sorts of funky thing
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 7, 2006
  • May 7, 2006
You can heat the screw to melt the locktite but you may melt the sensor too...I'd try a soldering iron if you have one. Maybve spray the piss out of it with some PBBlaster or something.
97gtconv.
244
Lock Haven, PA
May 7, 2006
  • May 7, 2006
i taped up the connection port and sprayed it with wd40. didn't work
damacman
529
Phoenix, AZ
May 7, 2006
  • May 7, 2006
Two suggestions:
1. Use a pair of good diagonal cutters. Come at the stuck screw head on (not perpindicular to it) and squeeze the cutters so that they bite right into the sides of the head at the center. While keeping the cutters pinched tightly, see if you can break the screw loose.
2. Use a dremel tool with a cut-off wheel and simply cut the head right off the screw.
Lucky for me, I was able to free both screws without too much pain when I upgraded my T/B.
GDawg
1,469
Nevada
May 7, 2006
  • May 7, 2006
I used a dremel to cut a deep thick slot so I could use a flathead screwdriver. I have a "T" type tool that has a flat head on it and you can really get some torque on the screw.
97gtconv.
244
Lock Haven, PA
May 7, 2006
#10
  • May 7, 2006
  • #10
thanks for the replies everyone
TPs sensors different?
  • Creomod
  • Sep 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2026
DadLife0724
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
