  • SN95 4.6L Mustang Tech
TPS Sensor Problem.
  • Thread starter Thread starter RobertLF42
  • Start date Start date Apr 6, 2011
RobertLF42
  • Apr 6, 2011
alright guys a have a question.. its a doozy.. my car was running like crap. i changed the ignition boots, the fuel filter, and spark plugs and it didnt do the trick.. my coil packs worked fine. then i decided to change the TPS sensor. that fixed the problem. the car runs like a dream. but when i go to start it up again it shoots me the "Service Engine Soon". the code is from the TPS. but when put on my old one the car runs like crap but the service engine soon light doesnt come out. now the TPS i got is from my friends 03 GT... Now both cars use the same TPS. by that i mean they're both the same part Number. my question is.. Why does the service engine light come on when i use the good TPS? and my ****ty TPS doest give the Code
stangvert
Maryland
Apr 7, 2011
  • Apr 7, 2011
adjustent?
Robert,
Did you adjust the TPS sensor? You have to twist it until the proper voltage is set on the sensor. I did it a long time ago. I'm sure you can find instructions on the internet for doing it. When I put my new plenum and throttle-body on there were instructions about how to adjust it. The car won't run properly if that voltage is not in the aceptable range.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Apr 7, 2011
  • Apr 7, 2011
The TPS on 96+ MY's do not have to be adjusted. The PCM "learns" the closed throttle voltage when the engine is started.
If someone is telling you that the TPS needs to be adjusted, they are thinking about cars 1995 and older.
It would help if you stated the model year of your car as well as the DTC codes.
It would also help if you explained in greater detail how the car was "running like crap".
When swapping TPS sensors, check to be sure there isn't a vacuum leak. IMO that is more likely the reason your car is running poorly.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
