98COBRA281 10 Year Member Nov 24, 2007 1,348 30 59 Port St. Lucie, Florida Mar 30, 2009 #1 Mar 30, 2009 #1 which wire on the TPS sensor is the "output voltage lead" :SNSign:
98COBRA281 10 Year Member Nov 24, 2007 1,348 30 59 Port St. Lucie, Florida Mar 31, 2009 #2 Mar 31, 2009 #2 anyone?!?!?! or is there a way i could find out which one it is?
SaleenGT2001 Well-Known Member Jul 18, 2005 2,811 4 58 Four Oaks NC Mar 31, 2009 #3 Mar 31, 2009 #3 checking now
SaleenGT2001 Well-Known Member Jul 18, 2005 2,811 4 58 Four Oaks NC Mar 31, 2009 #4 Mar 31, 2009 #4 check the grey/white wire. use a DVM and turn the car on but not running. ground the negative lead and probe the grey/white wire with the positive lead. move the throttle with your have and see if the voltage increases. if so you have the right wire
