tps sensor
nocaratall
132
im about to swap my stock tb/plenum for an accufab 70mmtb+plenum. i know the tps sensor is going to be a pain in the arse to remove (any tips on removal would be great). in the event i destroy the sensor trying to remove it and have to buy a new one, how do you set the voltage on it? anything else besides setting the voltage?? thanks.
I recently replaced the TPS on my Ranger. I removed the entire TB assembly because the screw heads for the TPS were so close to the firewall (no room for screw driver). Once I had access to the screws, I used a phillips head bit, a socket that the bit would fit in and a ratchet. This allowed me to put more torc on the screw than a regular screwdriver. The screws did have thread loc on them but it wasn't a problem. Just take it slow so you don't strip the heads.
Good Luck :nice:
Good advice from Jinx102672. :nice:
I also took mine off, put the whole plenum/TB assembly in my workmate vise and used my electric screwdriver. They are tight, but it's not that big of a deal. Taking it off the car is the key, as well as using the correct size screwdriver bit.
tl75keith said:
Maybe I have Hulk strength or they forgot to LocTite those screws when my car was assembled but for me they came out without a problem.
Hmmm, maybe my ripped purple jeans and frequent blackouts could explain it...
:lol:
thanks for the tips, ill give you guys an update later.
