TPS setting
Euphoric306
905
so i wanna make sure my TPS is adjusted correctly and i know it should be closest to 1 volt
...but there's three wires coming out of the damn thing and last i checked u only can have two wires hooked up to a DMM lol
so my ? is.... whch two wires do i test to adjust the TPS
and in which way do i move it to adjust it... rotate it? that makes the most sense to me since it seems to be connected to the axis of the butterfly valve in the throttle body... but i could be wrong
in the haynes manual it just says to leave this up to a professional... now i know why haha
The signal.
There is a ground, VREF (5v) and sig. It app 1.0V @ idle and 5.0V WOT. Might want to shoot for .95 or so. Anything over that will run rich. Unless you have a 89 or newer which resest the baseline every time you go to closed throttle. If that is the case, if your between .9-1.1V your fine.
Been a while since I've delt with OBD 1 stuff so the numbers may not be down to the nats ass. They're close though.
Mike has you covered pretty well. :nice:
Here is some info that might help.
If you only see 4.5 volts at WOT, that is pretty normal.
Good luck.
