TPS Voltage Readings
  • Thread starter Thread starter 93gtmustang
  • Start date Start date Mar 31, 2007
93gtmustang
524
43
49
Mar 31, 2007
  • Mar 31, 2007
I've always set my TPS this way with a digital voltage meter.
Positive to green TPS wire
Negative to ground on the frame
I thought I read on StangNet once, that you would get a more accurate reading
this way.
Negative to the black TPS wire
The reading I got using the first method (1.087), was a higher reading than the second method. (.96)
Which is the most accurate way to get a TPS reading?
Thanks
GT_green_GT
118
  • Mar 31, 2007
at tech school we always went to a ground on the vehicle.
310stanger
170
  • Mar 31, 2007
The correct way is on the TPS wires, not on the body of the car. Do it that way. Dont believe me ask Jrichker lol
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 31, 2007
  • Mar 31, 2007
All you need is less than 1.19 volt at idle and more than 4.25 at Wide Open Throttle (WOT). Somewhere between .50 and 1.1 is the best range. You'll need a Digital Voltmeter (DVM) to do the job.
The Orange/White wire is the VREF 5 volts from the computer. You use the Dark Green/Lt green wire (TPS signal) and the Black/White wire (TPS ground) to set the TPS. Use a pair of safety pins to probe the TPS connector from the rear of the connector. You may find it a little difficult to make a good connection, but keep trying. Put the safety pins in the Dark Green/Lt green wire and Black/White wire. Make sure the ignition switch is in the Run position but the engine isn't running.
Here’s a TPS tip I got from NoGo50
When you installed the sensor make sure you place it on the peg right and then tighten it down properly. Loosen the back screw a tiny bit so the sensor can pivot and loosen the front screw enough so you can move it just a little in very small increments. I wouldn’t try to adjust it using marks.
(copied from MustangMax, Glendale AZ)
1. Always adjust the TPS and Idle with the engine at operating temp. Dive it around for a bit if you can and get it nice and warm.
2. When you probe the leads of the TPS, do not use an engine ground, put the ground probe into the lead of the TPS. You should be connecting both meter probes to the TPS and not one to the TPS and the other to ground.
3. Always reset the computer whenever you adjust the TPS or clean/change any sensors. I just pull the battery lead for 10 minutes.
4. Check the procedure for your year, on my 90 I have to turn the idle screw until it just touches the tab, then insert a .010 feeler gauge and give it about one more turn.
93gtmustang
524
43
49
Mar 31, 2007
  • Mar 31, 2007
Thanks for the help.
I really appreciate it!
93gtmustang
524
43
49
Apr 1, 2007
  • Apr 1, 2007
Is this set with the key on, engine off?
Idle setting shouldn't exceed 1.00 volts right?
Adjust with the engine running at idle?
Thanks
I just want to know the proper way.
I read so many different methods.
Thanks again!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 1, 2007
  • Apr 1, 2007
Engine off, key on. If there are no codes set adjusting the TPS doesn't do anything. The TPS zeros out automatically everytime you start the engine.
See http://forums.stangnet.com/showthread.php?t=534062&page=10 and the comments by joel5.0 on the inner workings of the computer and how it uses the TPS. Very interesting stuff.
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
C
4375 auto meter air/fuel gauge
  • Canadianfox
  • Jul 27, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jul 27, 2025
Canadianfox
C
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
