TPS Voltage?
  • Thread starter Thread starter KBCobra95
  • Start date Start date Jan 7, 2006
KBCobra95
356
North Carolina
Jan 7, 2006
  • Jan 7, 2006
I checked my voltage on the tps and it only read .475? I thought it was supposed to be .987 or somthing? Is my sensor gone? Or is it fine? Thanks!
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jan 7, 2006
  • Jan 7, 2006
I think you must just need to adjust it... try loosening the bolts and turning it slightly to see if you can change the voltage
KBCobra95
356
North Carolina
Jan 7, 2006
  • Jan 7, 2006
I tried that but it stays around .475?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 7, 2006
  • Jan 7, 2006
Sometimes it is necessary to elongate the mounting holes.
Try this... Currently there is some dispute about setting it at .99 volts but anything less is probably OK. All you need is less than 1.0 volt at idle and more than 4.25 at Wide Open Throttle (WOT). You'll need a Digital Voltmeter (DVM) to do the job.
The Orange/White wire is the VREF 5 volts from the computer. You use the Dark Green/Lt green wire (TPS signal) and the Black/White wire (TPS ground) to set the TPS
Here’s a TPS tip I got from NoGo50
When you installed the sensor make sure you place it on the peg right and then tighten it down properly. Loosen the back screw a tiny bit so the sensor can pivot and loosen the front screw enough so you can move it just a little in very small increments. I wouldn’t try to adjust it using marks. Set it at .97v-.99v, the closer to .99v the better.
(copied from MustangMax, Glendale AZ)
1. Always adjust the TPS and Idle with the engine at operating temp. Dive it around for a bit if you can and get it nice and warm.
2. When you probe the leads of the TPS, do not use an engine ground, put the ground probe into the lead of the TPS. You should be connecting both meter probes to the TPS and not one to the TPS and the other to ground.
3. Always reset the computer whenever you adjust the TPS or clean/change any sensors. I just pull the battery lead for 10 minutes.
4. Check the procedure for your year, on my 90 I have to turn the idle screw until it just touches the tab, then insert a .010 feeler gauge and give it about one more turn. Then you adjust the TPS voltage to .98v, reset the computer. Start it up, if the idle is to low then turn the screw in until it is just right, then readjust the TPS voltage to .98v and reset the computer and start it up. The key is to adjust the TPS voltage and reset the computer whenever the idle screw is changed.
KBCobra95
356
North Carolina
Jan 7, 2006
  • Jan 7, 2006
ok, I went out and trid again. I misread it was 4.75 at idle? Isn't that supposed to be WOT Voltage? BTW This is on my 89 5.0.
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Jan 7, 2006
  • Jan 7, 2006
You did misread. Look below and read again.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jan 7, 2006
  • Jan 7, 2006
you must have checked the wrong wire , black goes to black and red on tester goes to green on TPS wires ....
rsw007
469
Lexington,SC
Jan 7, 2006
  • Jan 7, 2006
check it "key on, ignition off"
HISSIN50
34
129
Jan 7, 2006
  • Jan 7, 2006
How do you pull that one off?
I think you mean Key-on, engine off.
Look Its Aaron
2,634
Fontana, Cali
Jan 7, 2006
#10
  • Jan 7, 2006
  • #10
hahaha
mustangGT85
264
Orange CA
Jan 7, 2006
#11
  • Jan 7, 2006
  • #11
lol
rsw007
469
Lexington,SC
Jan 8, 2006
#12
  • Jan 8, 2006
  • #12
yeah thats what i meant. lol worked to many hours this week.
KBCobra95
356
North Carolina
Jan 8, 2006
#13
  • Jan 8, 2006
  • #13
I checked with red to green wire and black to ground and it was still 4.75 at idle.
04sleeper
2,674
14
89
Dallas, TX
Jan 8, 2006
#14
  • Jan 8, 2006
  • #14
Check the ground for the injector harness. I had a similar issue and had to connect a ground wire to the ACT sensor to get it working.
I did not trace the ground wires back to where it was loosing contact but it worked.
Edit: The ACT backfed the ground to the entire harness and the TPS sensor read correctly then.
joel5.0
429
Puerto Rico
Jan 8, 2006
#15
  • Jan 8, 2006
  • #15
Check the pins output from the TPS connector w/TPS disconnected w/DMM to ground, KOEO. You should have 0vdc at the Blk/Wht wire, 4.85-5.15vdc at the Org/Wht and 0vdc at the Dark Green/Light Green wire. If they chek out fine,....bad TPS , TPS needs replacement.
If the last pin check shows anything above 0vdc, need to do checks for wire shorts or...disconnect EGR Sensor to make sure it's not causing a short in the TPS circuit. My 2¢.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 8, 2006
#16
  • Jan 8, 2006
  • #16
Always take resistance measurements with the circuit powered off.
Check the black/white wire resistance. Connect one ohmmeter lead to the black/white wire on the TPS and one lead to the negative post on the battery. You should see less than 1 ohm, more than that indicates a problem.
Clean the 10 pin salt & pepper shaker connectors.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Electrical Stumped No Start...
  • sydhawk
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
sydhawk
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
