Just changed my throttle body today and went to install/adjust the TPS.
I've read two ways to get a reading. The first is to probe the green TPS wire + and the black TPS wire -. The second is with the green TPS wire + and battery ground -. And from what I've read, I should get a reading of ~ .9vDC?
Well, if I do it the first way, I get about .003v koeo. I drilled out the screw holes and was able to adjust it to .009vDC.
If I try the second way, I get about 4.5vDC. If I slide it around it moves in .00x vDC incriments.
What gives?? None of these numbers are even remotely close to what I've read they should be. I've tried this with 3 different TP sensors and have had the same results w/ all. And yes, I'm sure I'm using my meter correctly, and it's properly calibrated.
Any advice would be appreciated.
