TPS???
  • Thread starter Thread starter FordGuy88
  • Start date Start date May 12, 2008
F
FordGuy88
241
Park Ridge, IL
May 12, 2008
  • May 12, 2008
I am going to adjust my throttle position sensor. I was wondering what voltage it should be at, at closed throttle and wide open throttle?
Thanks,
Dave
joel5.0
429
Puerto Rico
May 12, 2008
  • May 12, 2008
Anything between .7 - 1.0 vdc will be fine, as long as you don't have a TPS failure code logged, why adjust it?
F
FordGuy88
241
Park Ridge, IL
May 12, 2008
  • May 12, 2008
.7-1.0v at wide open throttle? Im adjusting it because it is brand new and I want to make sure it is set correctly. Thanks.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
May 12, 2008
  • May 12, 2008
Most people say that, when closed, it should be at .9-1.0V for best performance. I don't think you need to be concerned what the voltage is at WOT so long as it is within range closed and not malfunctioning, but this webpage shows all you need to know:
http://fordfuelinjection.com/index.php?p=30
vristang
4,933
101
124
Seattle
May 12, 2008
  • May 12, 2008
WOT is triggered 2.7v above whatever your idle setting is...
Set idle to .8 and WOT triggers at 3.5v
Set idle to 1v and WOT triggers at 3.7v
oz
1,079
10
58
Plymouth, MI
May 13, 2008
  • May 13, 2008
Set it at .95-.99v key on, engine off. 1.0v tells the ECU that you are no longer idling and are now driving. This should give you slightly better off idle performance. WOT setting does not need to be addressed.
joel5.0
429
Puerto Rico
May 13, 2008
  • May 13, 2008
Nope..... closed throttle upper range extends to 1.19 vdc. Anything above 1.20 vdc = failure codes 23 and/or 53 will be logged. Anything below that threshold is "filtered"/set by the ECM as the minimum TP value to set the APT (At Part Throttle) flag to -1 or "closed throttle " value.... and I have a few cases that have the TPS (which is non-adjustable BTW) with closed throttle values between 1.0 and 1.1 vdc w/out any comebacks for years....... By the same token, I have other cases with the TPS closed throttle value between .6 and .9 vdc...... and no comebacks either.
oz
1,079
10
58
Plymouth, MI
May 14, 2008
  • May 14, 2008
I was speaking from memory - I could check the ECE manual but I'll take your word for it Joel.
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
TPs sensors different?
  • Creomod
  • Sep 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2026
DadLife0724
Electrical Stumped No Start...
  • sydhawk
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
sydhawk
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
