Trac-Loc vs. Locker
  • Thread starter Thread starter 70Machwon
  • Start date Start date Apr 16, 2004
70Machwon
35
Bay Area, CA
Apr 16, 2004
  • Apr 16, 2004
Now that my car is painted (pics to come soon ) It is time to look for some gears. I am thinking 3.50s, but i dont know weather to go for a trac-loc or a detrioit locker. My car is my daily driver, but i am not too interested in road racing, or turning fast, so i think the locker is the way to go. Also, what do you need for each set up. For the trac-loc, do you need a whole new third member and everything, or just gears?
Thanks for all the help, i am definatly a gearing noob.
Hack
1,945
Minneapolis
Apr 16, 2004
  • Apr 16, 2004
From what I've heard and read, detroit locker is not fun on the street. You'll drag one rear wheel in corners, since the wheels turn exactly the same amount all the time.
I would think that driving in the rain or any kind of slippery conditions could get treacherous as well. If you apply a little too much power, the back end will whip around so fast!!
I did that on my 6 cylinder with one-legged rear end and no horse power to speak of on an interstate on ramp. I was very lucky not to smash it. I drive extra carefully in the rain now.
65StangBoy
247
Phoenix, AZ
Apr 16, 2004
  • Apr 16, 2004
Lockers are not locked all the time. You will hear them ratchet as you go around corners which means that it is disengaging and engaging. I know there a many people here that drive them often, they should be able to tell you exactly what its like.
Timmy
315
Conway, Arkansas
Apr 16, 2004
  • Apr 16, 2004
Lockers are loud. Well mine is anyway. Yes, you can hear and feel mine ratchet in and out and yes, I do get wheel drag or skip when in parking lots or turning slow.
I want to replace my locker with a trac-loc unit or a newer locker but just haven’t done it yet because it’s not high on the priority list.
There are different types of lockers out there. I’m guessing I have an old style or maybe mine isn’t working correctly and that’s why it’s so loud. I’m told the new lockers are much quieter. Summit Racing has a nice locker for between $400 and $500 from what I remember.
1969mach1351
285
Sacramento, CA
Apr 16, 2004
  • Apr 16, 2004
I got a locker not very long ago and I after talking to many shops I was told if they are quite then they are not very good. A strong quality locker will always make noise. I can hear mine but not feel it ratchet; only when I give it gas to make it lock I feel it. In tight turns like in parking lots and stuff I can make it hop and screech but just under normal driving never on the road. If mine were a daily driver I would not want a locker. It gets annoying and in rain I can only just slightly crack the throttle in a turn or the back will swing out.
KillerKittyCat
150
Hammer Down - Behind The Wheel
Apr 16, 2004
  • Apr 16, 2004
Auburn gear will work if you do not mind the clicking. Mine works in the rain just fine and does not get sideways. Straight line burnouts are straight and hard corners work.
J
johnkn
24
Laplata, MD
Apr 16, 2004
  • Apr 16, 2004
I have one of each. For a daily driver I would suggest a T-lock. The locker is loud, harsh and rude, exactly what I want in the Shelby. You feel is as much as you hear it. A T-lock in good repair would be a better choice for a daily car... Good luck...
R
Ronstang
1,294
Houston Texas
Apr 16, 2004
  • Apr 16, 2004
I prefer the Trac-Loc for all but a true race car. Mine have served me well over the years and they are quiet. Lockers are great at the track but I'm not a big fan of them on the street but if you want to use one on the street FRPP sells (or at least used to) a ligher spring to be put in the locker that is not supposed to affect the locking feature under hard load but greatly reduces the hopping and racheting for casual driving.
Great68
691
Victoria BC
Apr 17, 2004
  • Apr 17, 2004
I want a Trac Lok for my 8", but they are all but impossible to find in canada.
R
Ronstang
1,294
Houston Texas
Apr 17, 2004
#10
  • Apr 17, 2004
  • #10
Original 8" Trac-Locs are hard to find anywhere. I just happened across one in a salvage yard about 10 years ago....and bought it for $40 even though Both my Mustangs have 9" rearends, couldn't just leave it there. To date it is the only original one I have ever seen in the wild.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Apr 17, 2004
#11
  • Apr 17, 2004
  • #11
I went with a LOCK-RIGHT instead of a locker. Its small and locks both wheels in a positive positraction but when you turn in unlocks, works great and it in my 8 inch. a little noisy but I dont hear it with 2-1.2 flowmasters.
65fastback2+2
1,229
Louisville, KY
Apr 17, 2004
#12
  • Apr 17, 2004
  • #12
i have a 4.11 locker in mine, you can hear the tires screech when you turn because they are turning the same amount.
70Machwon
35
Bay Area, CA
Apr 18, 2004
#13
  • Apr 18, 2004
  • #13
Wow, thanks for all the advice, i guess from what is said, the T-lock is the way to go. Now my other question. What is EVERYTHING i need for a complete T-lock conversion. I have a 9in rear-end.
1969mach1351
285
Sacramento, CA
Apr 18, 2004
#14
  • Apr 18, 2004
  • #14
I just bought a whole 3rd member from a company for my locker. Also did the 31 spline conversion. Buying the whole thing makes it easy to just drop in and know that it is built right. Moser, Strange, and Currie all sell everything you will need. I'd give one of them a call, they were all very easy to talk to. Also any transmission or rearend shop will do this for you but then you have to pay labor also. I'd also change you axle bearings while you are at it if you haven't yet. I have a Strange 3rd member and Moser axles. I'm not sure of each individual part you will need if you want to build it yourself.
G
glennv
39
#15
  • Apr 18, 2004
  • #15
I had a Powertrax No-slip on my 2002 Jeep Wrangler. It's is meant to be mild on the street. Let me tell you it sucks with a stick. I pulled it out and threw a Lcokright in the front. I have a Lockright in my Cherokee and I notice it less because it is an auto trans. Trans makes a huge difference.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Y
2004 Roush - Dome Lights and radio not working
  • Yurei
  • Nov 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 20, 2025
squeak93
