Track tomorow!
Hey guys im back from the track i found out from the previous owner my 280 solid lift cam was removed b4 it was sold, there is only a little better than stock in there now, not sure what.
Anyways first time at the track didnt do a good enough burn out roasted 1st and 2nd got down the track didnt know where the quarter ended, ended up slacking real early and running a 14.9 at 83 MPH lol but i had a .64 reaction time.
2nd run was better did a better burn out left the line with a .602 reaction time 2.149 60 FT, ran at 13.83 at 102 MPH
3Rd run i look at the lights to late was a .985 reaction, 2.106 60 FT ran 13.64 at 103.92 MPH
all this on 245,50,16s traction wasnt the greast still doing some spinning but when i was getting the tire warmed up more and more it was better,
ran 13.5 PSI in the rears, 32 psi in fronts.
I think for my first time at the track ever i did pretty good, and on streets at that i had room to improve my ET but in the gamble race i rolled past stage 2 and ****ing redlighted.
But i had a blast and will be back for more!!!:SNSign: :D
wow yea 13 psi is BAD for street tires, you should run rear street tires at about 25 at the lowest! That will definatly kill your 60'. I would have expected more out of that engine but 103mph is good for low 13's with traction!
If you go too low on air pressure with street radials, you'll actually LOSE traction. See, if you over-inflate a street tire, it balloons up and you only get a small contact patch in the center; if you seriously under-inflate them, the center portion of the contact patch will actually bow inwards a bit and you'll only have two small contact patches toward the sidewalls. You can run drag radials and slicks with really, really low pressure because they've got really squishy-soft sidewalls that allow for a lot of flexing, whereas street tires have much more rigid sidewalls and will become the weight-bearing part of the tire when the center part is under-inflated.
Over-inflating your front tires a little bit is nice as far as decreasing your rolling resistance, but seriously under-inflating your rears will not only kill your traction but run the risk of rolling the tire bead off the rim, which could be a bit dangerous. Running 12 psi is almost as bad as running a completely flat tire - mine gets a little squirrelly on the street if I have a leak and it starts getting around 20.
The lowest I'd ever go on a street tire would be 25, myself, MAYBE even 20 if you're running a tire with tall, soft sidewalls (like BFG Radial T/A's). Again, there's that point at which the tire goes from flattening out and making a wide contact patch to bowing upwards and leaving you with next to nothing. That might explain why you got so much wheelspin, which you could hear pretty clearly in the video by the way your RPM's went.
R/T doesnt affect 1/4 time...
Street Tires dont hook better that low, you just got it out of the hole better...
Pedal the car and it has more in it. Spinning like that and then hitting the next gear to spin through the next gear is NOT good for timeslips...
Keep at it, should go much faster!
