Traction-lock assembly help
http://www.corral.net/tech/drivetrain/gears.html
no pics,but good instructions.click on link and scroll down a little,you'll see it.
did you get the kit already?got mine from ampperformance.com.good price,fast delivery.
tip...get two long needle nose vise grips to compress the s-spring when you go to reinstall it,soak the clutch disc's in the friction modifier for a little while before you install them,i soaked mine overnight.replace the axle bearings and seals while your in there,at the very least the seals.
