  • SN95 V6 Mustang Tech
Traction lock for V6?
  • Thread starter Thread starter schoonover_88
  • Start date Start date Jul 19, 2004
schoonover_88
189
  • Jul 19, 2004
Hello, my name is Austin and I am realitivly new to the V6 crowd. My question is there any way to put traction lock in the V6 rearend, or do you have to switch over to the V8 8.8 rear? Thanks a bunch.
ryanrule
impotent
1,355
Madison, WI
Jul 19, 2004
  • Jul 19, 2004
there are tloks for the 7.5. minds well get gears if yur gonna open the back up. but then u need a chip too. so it would all run bout a grand. thats why i dont have tlock yet
schoonover_88
189
  • Jul 19, 2004
Thanks! Now does anyone know where I can get traction lock for the 7.5 rear?
J
Jamez
2,609
Tulsa, Ok
Jul 19, 2004
  • Jul 19, 2004
gefracing sells em for $169. I believe with a '98 you'd just have to get a speedo gear as I did which costs $15 from Steeda. I actually got a rebuilt one from the guy I had install my gears. Depending on what you wanna do, it might not be more than $500 for everything.
3.8L_of_Pain
123
Southern California -- Orange County
Jul 19, 2004
  • Jul 19, 2004
I also bought mine from gefracing when I had my six. Good prices and good service. Make sure you add the friction modifier when you install it.
L
Linz
"I Love Seamen"
1,551
Northern Virginia
Jul 20, 2004
  • Jul 20, 2004
I've got an Auburn T-lok in mine. Works quite nicely
schoonover_88
189
  • Jul 20, 2004
First of all, thanks for all of your help. But I am wondering if anyone can confirm that a speedo gear will correctly set my speedometer, and I will not have to get a chip or do anything else.
marvinmycat
1,179
Buffalo, NY
Jul 20, 2004
  • Jul 20, 2004
NO. The speedo gear will only get you CLOSER to the speed you are actually going. At speedo reading 65mph, you are only going 60mph.
You will have to pull your gauge pod face plate off and reposition your speedo needle. Use your fingers and just pull the needle off from the round black piece.
You can either have a friend pace you or go find oneof those road side MPH info trailers. I prefer to have a friend pace me. Also have someone else in the car with you to watch the traffic as you drive.
Find a nice quiet stretch of highway and have you and your pace car frined set the cruise at 65mph. Put your needle back on gently, not pushing it on all the way, at that speed when you are going the at the same pace. Also pull the 0 mph stop out, and when you stop the car and turn it off, push it the rest of the way on.
Go out and check your needle palcement again by having your frined pace you at the agreed upon speed again.
Or do what I did, find a speed trap and let them know your speedo is off!
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
SN95 V6 Mustang Tech Jan 19, 2026
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
SN95 V6 Mustang Tech Apr 30, 2026
badmech
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
