Before I installed my Edge converter, I was able to launch off idle on a 125 shot and hook up fairly well. I've been running 275/40/17 BFG drag radials on 17x8 Bullitt wheels. I deflate them to ~17PSI at the track and heat them up. I was able to cut 1.8 60's.
Now, I can't get traction on a 100 shot. The tires blaze off. Furthermore, early next year I'll be installing TFS heads, so traction will be even more limited.
I'm considering two options and would appreciate your input:
1. Mickey Thompson 26x10.5x16 ET Streets on the stock 16x7 waffle wheels. How much of a traction gain do you think I'll see with these tires? Could I make the 20 mile drive to the track on them? Will 26x10.5x16 slicks even fit my 16x7 waffles?
2. Mickey Thompson 255/50/16 ET Street drag radials on the stock 16x7 waffle wheels. How much of a traction gain do you think I'll see with these tires? Will there even be a gain over my 275/40/17 BFGs?
These tires will NOT be used for cruising the street or for daily driving. They will be bolted on in my driveway before going to the track, and then unbolted when I get home.
Thanks for your input.
