Tranny broken??
  • Thread starter Thread starter Georgie
  • Start date Start date Sep 20, 2006
Georgie
455
Montreal, Canada
Sep 20, 2006
  • Sep 20, 2006
Ok i fudged up my tranny...it just poped outta third and from then on every gear makes a **** load of noise and vibrations(knocking). i was able to get it back home...
i want to get a new tranny.. any suggestions?? i read that the t56 is good, but its freaking 3500$ plus i gotta get a longer speedo cable(cuz the hole for the speedo sensor is on the passenger side)...plus the mounts on the frame rail..anyways hears the link http://www.mustangandfords.com/techarticles/138_0309_viper_mustang_trans/
my question is is their any other suggestion and comments on this and other transmissions out their???
:SNSign:
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Sep 20, 2006
  • Sep 20, 2006
You could look at a upgrade for your internals. a g-force is a good tranny as well as the tko 500 and 600.
Sicarius428
2,085
Sep 20, 2006
  • Sep 20, 2006
Second the Gforce upgrade or a TKO500/600 upgrade. Do a search on the forum and you will find a lot of good information and debate between the two.
Kevin
Snikt89GT
264
Deland, Florida
Sep 20, 2006
  • Sep 20, 2006
Kevin
They want 2,000$ for those T5s
Georgie
455
Montreal, Canada
Sep 20, 2006
  • Sep 20, 2006
i might go to a crap yard and get an old one....what other cars has my exact T5 tranny in it...cuz if i tell the scrap guy its for a mustang hes gonna charge more for sure...
Georgie
455
Montreal, Canada
Sep 20, 2006
  • Sep 20, 2006
bump
Georgie
455
Montreal, Canada
Sep 21, 2006
  • Sep 21, 2006
bump
bullitstang1313
713
Indianapolis / Columbus, Indiana
Sep 21, 2006
  • Sep 21, 2006
You could always go for a T-5Z, its availble through Ford Racing and is supposed to have stronger internals and a less steep 1st gear. You could also have your transmission rebuilt. Just a couple of less expensive options, but it depends on how much power you are trying to get to the rear wheels.
Georgie
455
Montreal, Canada
Sep 21, 2006
  • Sep 21, 2006
right now im stock, but im building 600 whp + in the next few year on a dart block...
JChalfan
551
Bellevue, WA
Sep 21, 2006
#10
  • Sep 21, 2006
  • #10
I would probably suggest the junkyard route if you're on a budget like a lot of us. If my T5 gives out, I know that's what I'll be doing.
I don't know what other cars came with T5's. You could also check on Craigslist or other classifieds and find someone who's parting out a wrecked stang.
Jeff
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Sep 21, 2006
#11
  • Sep 21, 2006
  • #11
If you are building a dart block 600hp engine, don't waste a dime on anything other than a tk0 500 or 600. Because it's just money you'll have to spend twice if you buy something else.
Georgie
455
Montreal, Canada
Sep 21, 2006
#12
  • Sep 21, 2006
  • #12
I'm reading alot of bad things abut the TKO500/600...i think I'm going to go the G Force route......alot of ppl talk about having problems with missing 3rd..it doesn't grind, but just wont go in...
what do u guys think about the comments???
QUIKSVT
93
#13
  • Sep 21, 2006
  • #13
Do you have a short shifter by chance...
Georgie
455
Montreal, Canada
Sep 21, 2006
#14
  • Sep 21, 2006
  • #14
yeah..a hurst
Georgie
455
Montreal, Canada
Sep 21, 2006
#15
  • Sep 21, 2006
  • #15
ok i found a 4 banger 5 speed for 200$ cnd...will that fit??? cuz i just need the cheapest quick fix for now...just so i can move it around...
JChalfan
551
Bellevue, WA
Sep 21, 2006
#16
  • Sep 21, 2006
  • #16
Yep it will fit. I know it has a lower 1st gear than the V8 trans, but I'm pretty sure it will bolt right in. I also don't know if it is as strong as the V8 version. Someone here will know for sure, I know guys here have put 4cyl T5's in their cars.
You may also have to use the V8 bellhousing on the 4cyl trans, don't know.
Jeff
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Sep 22, 2006
#17
  • Sep 22, 2006
  • #17
You need a 4 banger pilot bearing to make it work.
Georgie
455
Montreal, Canada
Sep 22, 2006
#18
  • Sep 22, 2006
  • #18
can i get that from ford???
JChalfan
551
Bellevue, WA
Sep 22, 2006
#19
  • Sep 22, 2006
  • #19
Probably an auto parts store or ford.
Thanks for pointing that out 2000xp8, I had forgotten.
Jeff
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
Drivetrain At my Witts end Speedo gear ‘NEVER MIND’
  • Aoneill5.0
  • Dec 17, 2022
Fox 5.0 Mustang Tech Dec 18, 2022
Aoneill5.0
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
