Tranny broken??
Georgie
455
Montreal, Canada
Ok i fudged up my tranny...it just poped outta third and from then on every gear makes a **** load of noise and vibrations(knocking). i was able to get it back home...
i want to get a new tranny.. any suggestions?? i read that the t56 is good, but its freaking 3500$ plus i gotta get a longer speedo cable(cuz the hole for the speedo sensor is on the passenger side)...plus the mounts on the frame rail..anyways hears the link http://www.mustangandfords.com/techarticles/138_0309_viper_mustang_trans/
my question is is their any other suggestion and comments on this and other transmissions out their???
:SNSign:
I would probably suggest the junkyard route if you're on a budget like a lot of us. If my T5 gives out, I know that's what I'll be doing.
I don't know what other cars came with T5's. You could also check on Craigslist or other classifieds and find someone who's parting out a wrecked stang.
Jeff
If you are building a dart block 600hp engine, don't waste a dime on anything other than a tk0 500 or 600. Because it's just money you'll have to spend twice if you buy something else.
I'm reading alot of bad things abut the TKO500/600...i think I'm going to go the G Force route......alot of ppl talk about having problems with missing 3rd..it doesn't grind, but just wont go in...
what do u guys think about the comments???
Georgie said:
ok i found a 4 banger 5 speed for 200$ cnd...will that fit??? cuz i just need the cheapest quick fix for now...just so i can move it around...
Yep it will fit. I know it has a lower 1st gear than the V8 trans, but I'm pretty sure it will bolt right in. I also don't know if it is as strong as the V8 version. Someone here will know for sure, I know guys here have put 4cyl T5's in their cars.
You may also have to use the V8 bellhousing on the 4cyl trans, don't know.
Jeff
