Tranny Cooler Questions?
  • Thread starter Thread starter Scott_B
  • Start date Start date Jul 7, 2004
Scott_B
"1 Arm Wonder! "
4,197
NS Canada!
Jul 7, 2004
  • Jul 7, 2004
Adding an AOD, so i have to get a tranny cooler. Do they come with all the piping or hose to connect them? Can you use copper tube? or is braded hose better? Figure that would be very costly though. Also, it looks like i have the conections on my rad to add the cooler lines. Im wondering, could i put plumb it, so it goes to the rad, back out, then to the tranny cooer, then back to the tranny? Or would it be better just to go to the cooler and skip the rad?
StonysGT
220
winamac, Indiana
Jul 7, 2004
  • Jul 7, 2004
what did you do with your manual?
Scott_B
"1 Arm Wonder! "
4,197
NS Canada!
Jul 7, 2004
  • Jul 7, 2004
Broken arm, going auto for the summer.
StonysGT
220
winamac, Indiana
Jul 7, 2004
  • Jul 7, 2004
you already got the aod
Scott_B
"1 Arm Wonder! "
4,197
NS Canada!
Jul 7, 2004
  • Jul 7, 2004
yup, have the aod and all the stuff to go with it, minus the tranny cooler. i bought a baumann shift kit to help out, would like a better stall then stock though..just dont want to spend a fourtune on a (hopefully) tempory thing.
Scott_B
"1 Arm Wonder! "
4,197
NS Canada!
Jul 8, 2004
  • Jul 8, 2004
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 8, 2004
  • Jul 8, 2004
If the radiator's already set up for it, I'd hook them up there - especially if it's a temp thing. If it's longer term, I'd go with an aftermarket setup. Most come with all you'll need to hook them up. I'd consider mounting the cooler down low and off to the side underneath the car, so the hot air coming off of it doesn't pass back over the radiator making the rad work harder. And up there in Nova Scotia if you end up leaving the aod in, I'd plumb it out from the tranny to the auxillary cooler then to the radiator then to the tranny. That way in the winter, if the auxillary cooler works a little too well, the radiator cooler will put some heat BACK IN the fluid. You can use copper line or braided stainless, but if you're careful with the routing and covering of the kit's rubber lines, they'll work just fine. I've been adding auxillary oil coolers for decades to my cars - always used the high temp/pressure rubber lines that came with the kit. Never had a problem. One of them lasted for a good 8 years on my SCCA racer.
rsw007
469
Lexington,SC
Jul 8, 2004
  • Jul 8, 2004
get the b&m 24000gvm around 50 bucks, thats what i have it does fine rubber line will be fine just watch where you route it. since its temporary i wouldnt worry about the rad. just the cooler will be fine.
Scott_B
"1 Arm Wonder! "
4,197
NS Canada!
Jul 8, 2004
  • Jul 8, 2004
Cool! Thanks for the help! Can you get the fittings for the rad from ford? Right now it just has plugs in it.
Also, im not too worried about the winter, as its a summer only car. But that would probably be a better idea, run it to the cooler then to the rad! How much rubber line do these kits come with?
rsw007
469
Lexington,SC
Jul 8, 2004
#10
  • Jul 8, 2004
  • #10
mine goes thru rad. then cooler. they dont come with much2 feet or so
Scott_B
"1 Arm Wonder! "
4,197
NS Canada!
Jul 8, 2004
#11
  • Jul 8, 2004
  • #11
Cool..im sure i can find some line at our local shop. What size is preferable?
rsw007
469
Lexington,SC
Jul 9, 2004
#12
  • Jul 9, 2004
  • #12
depends on cooler
I
2000 GT Mustang - Transmission Cooler to Radiator o-rings
  • Iwarrior
  • Oct 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 4, 2025
Iwarrior
I
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Vortech v3 Si Blow-Off Valve
  • seanmahoney
  • Jun 9, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 9, 2025
seanmahoney
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
