  • 1994 - 1995 Specific Tech
Tranny drop (help)
  • Thread starter Thread starter Therian
  • Start date Start date May 19, 2006
First Prev 2 of 2
Therian
The Highlander
Waterloo, Ontario
May 21, 2006
#21
  • May 21, 2006
  • #21
drakesdad said:
Sorry Therian......I have shorties so I can't help......no experience with LT's
No problem man, your helpfulness has been noted
Somebody else with long tubes must have done a clutch swap at some point?
I guess it's just a question of how much more work it would be to take the long tubes out at this point...They're pretty rusty anyway (I have no idea how) and they could use a good coat of super high temp paint
drakesdad
961
Oregon OHIO
May 21, 2006
#22
  • May 21, 2006
  • #22
TTT
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
May 21, 2006
#23
  • May 21, 2006
  • #23
I don't have experience with LT's on our cars .... but if I was having some clearance issues (I have shorties), I would loosen all the header bolts and screw them ALMOST all the way out ... leaving a few threads. You might could try that. Maybe you can nudge the headers around just enough to get the clearance you need by doing that.
If you have the time and keep the car "down" just a little longer .... I'd just remove them and give 'em a good coating while you're there. You'll probably have to lift the engine a little to do that, though.
Therian
The Highlander
Waterloo, Ontario
May 21, 2006
#24
  • May 21, 2006
  • #24
This is what I was thinking...I'll do some more research...Can you lift the engine using a normal 2.5 ton hydraulic jack? If anyone has long tubes and has any advice I'd appreciate it. Thanks guys.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
May 21, 2006
#25
  • May 21, 2006
  • #25
I suppose you could use that .... but be careful. I'd rather use a regular floor jack with a block of wood, though. Just unbolt the steering linkage (not hard ... takes all of a couple of minutes). Then you should be able to work the driver's side header out throught the top. Then loosen engine mounts. Jack engine up a couple of inches (jack on the FRONT sump of the pan). Slide engine slightly to the right if needed. Work passenger side header out.
Therian
The Highlander
Waterloo, Ontario
May 21, 2006
#26
  • May 21, 2006
  • #26
Something tells me it's going to end up being a little more difficult than that
SeventyMach1
Mar 30, 2005
1,940
North Carolina
May 22, 2006
#27
  • May 22, 2006
  • #27
Always.
But do this. Always go into it "expecting the worst". That always helps. Good luck man.
Therian
The Highlander
Waterloo, Ontario
May 22, 2006
#28
  • May 22, 2006
  • #28
Did quite a bit of research on this topic...and it seems as though the question has been asked several times but never answered.
Has no one done a clutch swap that has long tubes?
First Prev 2 of 2
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
