  • SN95 4.6L Mustang Tech
tranny loose/ Possible?
  • Thread starter Thread starter 00GTpony
  • Start date Start date Jun 2, 2007
00GTpony
162
  • Jun 2, 2007
I feel like when i hit a bump my tranny is movin around, i can feel it in the shifter... is there sumthin in the tranny it could be, or is it possible it could b the tranny, it makes a noise sometimes to.. on turns i feel it to sumtimes... please help?
Superhereaux
chicks make me feel inadequate
538
South Texas
Jun 3, 2007
  • Jun 3, 2007
it probably is moving around, check the trans mount
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Jun 3, 2007
  • Jun 3, 2007
jack it up and check it. im pretty sure though if the tranny is loose you will have issues with clutch engagement, since the disk/pp will be off whack.
do you have an aftermarket shifter? if so, are the 4 bolts that hold it in still tight?
could it be motor mounts and/or any other bushings for the driveline that cause that? i know the mounts on my 91 GSX are going out and the shifter moves a quarter inch if i go from accel to decel. but its a totally different driveline than a rwd car.
00GTpony
162
  • Jun 3, 2007
i guess ill jack it up and check it out tomarrow...
Fog horn sound
  • brandon4v
  • Jun 22, 2026
SN95 4.6L Mustang Tech Jun 23, 2026
squeak93
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
