tranny loose/ Possible?
00GTpony
162
I feel like when i hit a bump my tranny is movin around, i can feel it in the shifter... is there sumthin in the tranny it could be, or is it possible it could b the tranny, it makes a noise sometimes to.. on turns i feel it to sumtimes... please help?
jack it up and check it. im pretty sure though if the tranny is loose you will have issues with clutch engagement, since the disk/pp will be off whack.
do you have an aftermarket shifter? if so, are the 4 bolts that hold it in still tight?
could it be motor mounts and/or any other bushings for the driveline that cause that? i know the mounts on my 91 GSX are going out and the shifter moves a quarter inch if i go from accel to decel. but its a totally different driveline than a rwd car.
