Tranny Noise
I recently did a Spec stage 3 clutch/flywheel upgrade. And now I have a noise coming from the tailshaft of the transmission. It sounds like a bearing noise and it can only be heard while the car is moving, doesnt matter if the clutch is in or out. I tripple checked and torqued everything to spec. Used an oem tob also. I thought maybe I messed something when I put the drive shaft back in because it did give me a lil trouble going back in, so I pulled it back out and pulled the output shaft seal and everything looks normal :shrug: Would the pilot bearing send a noise through the tranny? Im kinda stumped here
