Tranny problem
  • Thread starter Thread starter stang0f87
  • Start date Start date Nov 19, 2004
stang0f87
102
Fort Smith, AR
Nov 19, 2004
  • Nov 19, 2004
ok i've got an 87 gt. i'm certain the 5 speed transmission has never been rebuilt, but its never given me any problems till recently. It shifts alright till i get on it real hard and try to grab 2nd gear. CLANK! A buddy of mine told me it could be the synchronizers going out. Also, when I'm parked in a confined area I can hear it humming until I push the clutch in bout half way. I noticed that today. I'm in the process of building a 347 with a c6 tranny so if this is a big enough problem due to wear and tear i'll probly just say heck with it for now and hope it'll last a little longer. I pulled up on the clutch pedal to make sure there was no slack. what do you guys think?
87 gt
stock 302
gt40 heads
x-pipe
5 speed
EMW150
2,020
Roaring Spring,PA
Nov 19, 2004
  • Nov 19, 2004
Well, the humming most likely is throw out bearing related. A clunking usually isn't synchronizers. Synchronizers will start grinding and make it hard to get into gear.
V
v8only
2,378
22
49
Nov 19, 2004
  • Nov 19, 2004
I agree, bad sincros will grind, not clunk.
i'd look at your driveshaft u joints. Also be sure your trans to bell and bell to engine bolts haven't worked themselves loose.
as for the t/o bearing noise, if it's a squeak it may just be an adjustment, you can try tightening the adjustment a little.
http://50stangs.com/techarticles/clutchcableadjustment.html
Kurtis
79
  • Nov 19, 2004
Same thing happens to me and I've got a brand new T-5 in there, so I doubt it's tranny related. My friend thinks its normal. He's got a z28 six-speed and it does the same thing, but he'll be replacing the clutch soon so we'll be able to tell if thats the culprit. Let me know if you figure it out first.
Funanin
356
Horsham, Pennsylvania
Nov 19, 2004
  • Nov 19, 2004
if it is a real quick grind that sounds like a clunk, then it is the synchos, because mine also went from 2nd to 3rd first, then somehow moved from 1st to 2nd, then 2nd died and i had to replace the whole thing. just my $.02
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
