tranny problems
  • Thread starter Thread starter 87_GT
  • Start date Start date Jan 5, 2006
87_GT
179
tinley park, illinois
Jan 5, 2006
  • Jan 5, 2006
i was driving around earlier and i had a couple of people in my car so i decided to get on it from a light. when i went to shift hard into 2nd i messed up and heard a bad grinding noise. well when i stopped at the next light, my trans was really hard to get into 1st and then even harder to get into second. it goes into the other gears with no problem. but when driving it the rest of the day it was way to hard to get it into 1st and 2nd. do any of you geniuses have any advice or insight? thank you
Modular2v
3,222
23
99
oklahoma
Jan 5, 2006
  • Jan 5, 2006
congrats you just blew your syncronizers! nothing a tranny rebuild cant fix
M
Marlboro_Man
437
Houston, TX
Jan 5, 2006
  • Jan 5, 2006
I would start by checking your clutch cable and if your running the stock quadrant i would definatly check that.
Start with the cheaper , simpler things.
5.0 Nostalgia
904
CT
Jan 5, 2006
  • Jan 5, 2006
I agree, you probably blew something up. Most likely a piece of metal from the gear or synchro is stuck somewhere in your 1-2 cluster and is causing it to jam up.
rd
3,316
63
109
Ocean Springs MS
Jan 5, 2006
  • Jan 5, 2006
Most likely the final gasp of worn 2-3 synchros in the 1-2 shift area. Could be a bent shift fork, or lost pads on the end of the shift fork, but I would pull it with the idea or replacing the 1-2 stuff.
Not real hard to do or uncommon.
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Jan 5, 2006
  • Jan 5, 2006
Do yourself a favor and when that tranny finally go's ka-put (and its only a manner of time before it does now), drop an extra $500 bucks ontop of the $650-$850 they're going to charge you to rebuild and buy yourself a Tremec, a T5 isn't worth a **** in my book, done went through two and i still ain't learned my lesson yet...Oh well...
87_GT
179
Jan 5, 2006
  • Jan 5, 2006
thanks for all of the replys. it was only a matter of time before it went. it has 156k on it and i drive it pretty hard.
Modular2v
3,222
23
99
oklahoma
Jan 5, 2006
  • Jan 5, 2006
g force the thing and never worry about it again!
Sicarius428
2,085
Jan 6, 2006
  • Jan 6, 2006
Just ordered a rebuild kit for 330 shipped from hanlon with the 1-2 shaft, steel bearing ring and video. If you are on a tight budget you can go that route.
Kevin
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
