TRanny problems
  • Thread starter Thread starter Kgporkchop
  • Start date Start date Aug 20, 2007
Kgporkchop
392
olathe, Ks
Aug 20, 2007
  • Aug 20, 2007
After owning 6 mustangs you think I would have known better then to buy a Auto. MY 01 Gt that I purchased in April is leaking tranny fluid from the tranny pan, and from the front at inspection plug. I had AAMCO look at it on Friday and they said that it was internal, and the only way to find out what the problem was is to pull the tranny and tear it down. The cost would be between $1400 and $2200. The car shifts fine on the highway and on normal driving. But it is leaking, the shop said that it should hold for about 90 days or so. So do Irebuild the auto or do a conversion. If i stay with the auto I thought about doing a stall converter and a shift kit. I do a conversion I have a guy with a totaled 03 GT, that I can get all the parts for about$1100. ANyone have any suggestions.
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 20, 2007
  • Aug 20, 2007
1400-2200 to tear it down and find the problem or to fully rebuild it? I went through the same quandary when i had tranny issues about whether to convert to a 5-speed or not. I went the rebuild w/ stage II kit, new reworked valve body and stall converter + tranny cooler (the worx) and every day im glad for it. It come down to the fact that i spent $400 less totally rebuilding my tranny to now handle 550+hp and awesome shifts than i would have buying a low millage/new stock spec run of the mill 5-speed and putting that in. Of course this is with my dropping and re installing the tranny but this still applies.
But why are you at this crossroads with just a leak and no mechanical problems that you know of?
Modular2v
3,222
23
99
oklahoma
Aug 21, 2007
  • Aug 21, 2007
sounds to me like they are trying to pull a fast one on ya! Replace the pan gasket and make sure you stay constant on fluid levels and save yourself the headache and money
gtsr281
  • Aug 22, 2007
Your pan is no problem, could just check to see if it's tight and replace the gasket. The other situation could be that the pump is loose......or the torque converter welds are letting go, I have seen this happen. I put the transgo HDII shift kit, B&M 24K GVW cooler on, and redline clutches in. Lets just say she mighty playful now. The torque converter i'm gonna use is a 2400 stall but T/C usually cost starting out at $450 for a decent one. I have the 4r70w and am sure you do so stay away from shops and follow these or other instructions. Total in repairs roughly $700+
J
jloc_stang03
whidbey island, wa
Aug 23, 2007
  • Aug 23, 2007
i have a 2003 mustang gt convertable and i just had a new corbra clutch kit installed and my tranny fluid change but the clutch still makes a little chattering noise but goes away when i push on the clutch its not loud or anything i have to put my head down lower to hear it. the people that put the clutch in said that it is normal and it will go away in about 500 to 1000 miles when the clutch is fully broke in, but also when u rev it up while ur in nuetral it u can also can hear rhe chattering noise to. I am just to find out if this is normal or not .
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 24, 2007
  • Aug 24, 2007
jloc_stang03 said:
anyone know what kind of tranny fluid goes in a 03 mustang GT
use Mercon V or Mobil 1 synthetic ATF
Kgporkchop
392
olathe, Ks
Aug 24, 2007
  • Aug 24, 2007
I had a few more shops look at my tranny, and a friend suggested a shop not to far from my house. I took the car in last week he looked at it and said around $350 to pull the tranny and replace a gasket on the inside, and that price was good for him installing a shift kit. There are no problems with the tranny other then it leaks. He acted like it was not that big of a deal, and said he would have it done in a day. SO i am ordering a trans go shift kit this week.
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 24, 2007
  • Aug 24, 2007
sweet
scupking
1,186
Enfield, CT
Aug 24, 2007
  • Aug 24, 2007
I just had my tranny rebuilt last month. About a week after having it rebuilt it started leaking. I took it back in after a month and they said the new bearings they put in failed and are all chewed up. So I got the car back again 2 days after they replaced the bearings for the second time. Go on my lunch break yesterday and notice a small little puddle under my tranny. So it’s leaking once again. Also my 3.73s that I had put it are whining at 50mph with overdrive on. I paid $1,000 for the tranny rebuild. Granted they changed the bearings for free this time around.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
R
1965 C4 Tranny leaking?
  • Rick1965Coupe
  • Jul 28, 2024
Classic Mustang Specific Tech Aug 7, 2024
Rick1965Coupe
R
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
