tranny question
I know the Tremec will get bookooboodles of votes but I think the G Force should be considered. You can get gear ratio options, it's lighter than the Tremec and there's no issues with installation. There's different types of sychros too if that's your thing but most of all it's just as of not stronger than the Tremec. Both are good and you can't go wrong but there is another choice than the standard Tremec 500/600/TKO.
I have recently done alot of research on tranny's because mine was busted. After reading many posts on here, and talking to the people at G-Force I will be going for the G-Force. It seems as though the TKO-600 is the strongest, but with posts saying that people are spending 2500-3000 dollars for the swap it is just to much for me. The G-Force trans will hold 500 ft-lb and only costs about 1500. If you dont mind some gear noise the Dog Ring upgrade on the G-Force will hold up to anything the TKO-6000 will and only costs 2000. I Think that if money wasnt an issue though I would go with the TKO-600
