Tranny shudder
  • Thread starter Thread starter Catsup
  • Start date Start date May 16, 2006
C
Catsup
  • May 16, 2006
I've got '97 GT that's still stock except for K&N air cleaner and flowmasters (yeah I know but you gotta start somewhere!).
I've got a bad case of the shudders between 2 & 3rd unless I'm under heavy acceleration. Any ideas what would cause that?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 16, 2006
  • May 16, 2006
Depends on what kind of shutter...could be a tranny mount or a bad u-joint...or something else.
Give more detalis for us.
C
Catsup
  • May 16, 2006
It sounds (and feels) like when you drive over a rumble strip - you know, those rapid-fire bumps they put right before toll booths to get your attention. If I back off the gas a little it stops immediately and I can get right back on the gas with no shudder.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 16, 2006
  • May 16, 2006
So it is while it is in gear?
Jack it up and check the driveshaft. See if it has any play at the u-joint.
QuickCapri83
80
North East, PA
May 16, 2006
  • May 16, 2006
Too odd. It only does it in two gears, but will go away if you back off it and get back on the throttle? Sounds alot more like an engine/ignition problem. I had a few bad wires on my 83 capri and it caused the engine to vibrate so bad it would rattle your teath when driving it. I dunno clueless here.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 16, 2006
  • May 16, 2006
This is a common problem with early 4R70W's. There's actually a Ford TSB on it (98-8-7). The problem is heat. When excessive heat is present, it creates a breakdown of the oil/friction material interface. The cure calls for the addition of an external transmission cooler to keep fluid temperatures down and the switch to the improved Mercron V transmission fluid.
This would be a good time for a torque converter flush and the addition of a new transmission filter while you're at it.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
