Tranny Wiring Harnesses
  • Thread starter Thread starter Deleted member 87397
  • Start date Start date
D
Hey All,
I'm about to wrap up my T-5 swap and I have a question or two. There are two wiring harnesses in the trans tunnel that were connected to the AOD. One is a 4 wire and one is a 2 wire. I know I don't need to use them both, but I want to know what each harness is and which one I need to use for the reverse lights. The T-5 Harness has 2 wires and a jumper on it so my guess is that I only need 2 wires from the original 4 wire harness and I can just cap off the other two. If that's the case, what is the other 2 wire harness in the tunnel for? Neutral safety switch? I dont see a spot for another switch on the trans. Do I need to jumper anything down there? I hope this makes sense. Any help would be appreciated.
