Tranny??
v8only
2,378
22
49
the problem you're going to run into likely is a different input shaft length. I'll assume the bell mounting holes are in the same location, which you'd have to verify. What you're going to have to do is measure and compare input shaft lengths. So long as the bell mounting holes are in the right place and the input shaft is the right length (you'll likely have to swap a mustang input shaft onto it) you'll likely be good to go, but that's just an educated guess. Another thing to check is the spline count in the tailshaft and input shaft.
Sicarius428
2,085
300zx also uses a hydraulic clutch setup. Don't think that should pose a problem if you are going to use your current bell and such... just another possible issue.
Kevin
