trans / clutch problem ?
  • Thread starter Thread starter bnws
  • Start date Start date Oct 3, 2010
bnws
18
  • Oct 3, 2010
70 mach 1, 4 speed top loader. When letting out clutch in first gear, I hear a brief screechey noise at point of engagement, will also hear in reverse, and when shifting into 2nd, although not as bad into 2nd. can also feel slight vibe in pedal at same time noise is heard .Noise started recently and seems to be getting worse. there is no clutch slipage, and no noise when depressing or releasing cluth pedal if trans not in gear, any help pointing me in right direction would be appreciated
rbohm
6,698
550
204
tucson,az
Oct 3, 2010
  • Oct 3, 2010
it sounds like the throw out bearing is starting to seize up under load. eventually it will seize up without the load.
D
D.Hearne
11,730
south louisiana
Oct 3, 2010
  • Oct 3, 2010
x2
68RCodeConv
345
Houston, TX
Oct 8, 2010
  • Oct 8, 2010
Throwout bearing.
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
