trans getting stiff grinds reverse
  • Thread starter Thread starter booger815
  • Start date Start date Aug 25, 2005
booger815
hebron kentucky
Aug 25, 2005
  • Aug 25, 2005
please forgive me for being a newb i have to start somewhere, but this is my first mustang and i have only had it for 3 weeks now but my question is the trans in it was always a little stiff but now its getting hard to get into gear and it is grinding reverse almost every time. it has the original clutch in it is all i can really say and it has a pro 5.0 short shift installed but i was wondering if it was my clutch going out or if its my trans. or something else entirely. i would have searchd to look around for similar threads but i am at work and in a bit of a hurry. thanks for any help.
T
tjm73
2,418
Rush, NY
Aug 25, 2005
  • Aug 25, 2005
What do y ou mean by "the trans in it was always a little stiff but now its getting hard to get into gear and it is grinding reverse almost every time."
Most T5's will grind going into reverse becasue reverse is not synchronized. If you push the clutch in and wai ta few seconds you should be able to go in just fine with little, most often no, grinding.
Your description of the problem is kinda vague.
89lxsport50
550
Franklin Tennessee
Aug 25, 2005
  • Aug 25, 2005
Try putting it in 5th. before you put it in reverse. Reverse does not have synchros. If you are having trouble shifting between other gears, it may be time for a new clutch cable. Only use a Ford non adjustable cable, available for under $50 online. The dealer will charge an outrageous price for the same part. You may want to get an aftermarket quadrant and firewall adjuster if you don't already have one.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Aug 25, 2005
  • Aug 25, 2005
The previous posters have explained why you are grinding... But as for your stiff transmission, have you changed the fluid in there yet?
89lxsport50
550
Franklin Tennessee
Aug 25, 2005
  • Aug 25, 2005
By stiff do you mean you are having to use more force to pull the shifter out of one gear and into the next?
booger815
hebron kentucky
Aug 26, 2005
  • Aug 26, 2005
yeh sorry for being vegue on what stiff was i do mean it is harder to shift out of a gear and into nutral and i talked to the guy i bought it from and it is a stock clutch / clutch cable and the car has 77,000 miles on it so it is probly a good time to change it out. thanks for the help.
89lxsport50
550
Franklin Tennessee
Aug 26, 2005
  • Aug 26, 2005
I had the same problem on mine. Only mine has 191,000 miles on the original clutch and cable. The clutch is not slipping at all, even with a leaking rear seal, believe it or not. It was getting hard to pull out of one gear and into the next, but was not grinding. I replaced the cable and quadrant with a Ford cable and Maximum Motorsports quadrant and firewall adjuster. It shifts like butter now.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
