Trans leak
Just check the fill and drain plugs for tightness (the two square-drive plugs on the passenger side). When you refill the trans, it is a good idea to put sealer on the plugs, too. Its not uncommon to leak from the tail housing seal, too, so look back there for dripping.
It sounds like you are having a LOT of problems with this build...
hahaha yeah nothing like i was having before the rebuild though!
the water pump ended up being lose bolts becaus of the new gaskets
i just went through and re torqued every bolt i could
i just smelled something funny so i looked under the car and saw red tranny fluid dripping on the x pipe
thanks so much for the help man!
ill check it as soon as i get home
