Trans Pan Q
bluemustang00
89
new britain,ct
I just found out I have a hellva trans leak from the pan. I ordered the gasket and the sent me two differ gaskets. I have an auto. Anyone know the part # or which gasket it could be by describing it? I got the gaskets from Napa. Any help would be good.
Thanks
why don't you just look at the size and shape of it and put the right one on. it is either a cork or rubber gasket. you could have just used silicone gasket maker and been done with it.
Hey man im not all that mechincal smart. You act like I had the damn transmission in between my legs and same wit gaskets. Theres a thing called work :rolleyes:
Secondly its not whether its corked or rubber cause there both corked. its just the parts numbers on it. They didnt know so they sent both.
A4LD 2WD 89-up
AOD (FIOD)
Im just presuming its the AOD since I finally looked at the gaskets unlike before.
