Trans question ...
I'm not sure if the V6 SN95 cars used the same T5 as the 5.0 models, but if they did, it'll have an input shaft that's 5/8" longer than the Fox T5. You could probably use it, but you'll have to use the correct bellhousing. If I'm not mistaken, the 3.8 and 5.0 use the same bolt pattern for the bellhousing to the block, so you could probably use the one you have.
