  • 2.3L (N/A & Turbo) Tech
Trans swap
  • Thread starter Thread starter godM0d3
  • Start date Start date Sep 11, 2007
godM0d3
Cookeville, TN
Sep 11, 2007
  • Sep 11, 2007
I'm swapping the auto trans in my '90 LX for a T5 from T-bird. The guy at the junk yard said it was an '86, but I found out the '86 had cable clutch setups. I guess it's from either an '87 or '88 instead. I'm wondering if anyone has any suggestions for setting up the hydrolic clutch on my mustang.
Dr_EluSivE
2,155
Central Illinois
Sep 11, 2007
  • Sep 11, 2007
Yeah... Dont.. I would try to find a cable bell housing and pedal assembly and use that. Hydraulic clutches are a pain.
Dr.
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Sep 12, 2007
  • Sep 12, 2007
If it's from a Turbo Coupe you'll also have to swap the speedo gear in the transmission because the T5s behind turbo engines had a different one from the n/a ones.
godM0d3
Cookeville, TN
Sep 22, 2007
  • Sep 22, 2007
So no one has used the hydraulic clutch set up in a fox body? I've seen pictures of it, but no kind of instructions to help do it.
mr_woodster
1,314
Riverside, CA
Sep 22, 2007
  • Sep 22, 2007
Sorry, its just not a popular thing to do. The standard cable setup is less hassle and is easy enough to push down. If you have disabilities which prevent you from driving a standard car then i could see it being a acceptable idea.
Biffmeistro
87
  • Sep 22, 2007
Hey, see if you can get the engine from that car too! If you're swapping the transmission, might as well swap the motor at the same time.
Stinger
7,754
24
118
Basehor (Kansas City), KS
Sep 24, 2007
  • Sep 24, 2007
It's a direct swap if you choose to do so, just hook everything up the same as it is in the TC.
godM0d3
Cookeville, TN
Sep 25, 2007
  • Sep 25, 2007
I was actually there for the engine, but it was no good. No plugs in the holes, so it was rusted up inside and out.
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
C
5r55s auto to TR3650 Manual swap 4.0 V6
  • Ceskz
  • Feb 24, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Mar 27, 2025
89ripper
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Dec 26, 2025
AeroCoupe
82 Gen 1 Coyote Swap AC Questions...
  • thinkfaster
  • Aug 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
thinkfaster
