SN95 Trans Thoughts?
I was going to go with the base tfs kit but Ive been researching and I def want bigger heads and a more aggressive cam I was thinking AFR 185s or a tad bigger. What about the afr205s are they streetable or is it going to be too much?
I don't blame you for checking up on the info I gave you already and hearing it from multiple sources. I have AFR 205s on my 331, and there is no issue on the street. Just cam it right. You won't need a big one.
Im prob goung to go with the setup you were talking about. Sucks the 205s are so expensive I looked into the afr205s and they were over 2 grand. Is it worth the extra buck over the 185s?
I couldn't tell you that. I only told you the way I would build a 347 if I built another one. I've had AFR165s, and 205s, but not 185s. Is an AFR205 too much head on a 347? Absolutely not.
