Transgo vs Baumann shift kit's
  • Thread starter Thread starter Billy88LX
  • Start date Start date Jun 17, 2004
Billy88LX
157
Alberta, Canada
Jun 17, 2004
  • Jun 17, 2004
I'm looking to get a shift kit for my 88lx aod. I have 3.73 gears and a 3000rpm non-lock tq. Engine wise gt40p,explorer int,long tubes, 1.7 rockers and making peak hp around 5400rpm. Which is the better kit? My concern is that you can't adjust the shift point's with the transgo (I think they only shift as high as 5000rpm). The Baumann you can set 1100rpm above stock point's, plus the shifting into OD at wot concern's me. Does the transgo act like 1 is 1, D is 2nd OD is 3rd and OD? Is the Baumann like that too? Price is not a concern I just want the better kit.
ss93cobra
1,422
Wilmington NC
Jun 17, 2004
  • Jun 17, 2004
The only piece of information I can provide is that the Transgo shifts much harder than the Buamann kit. I've got buddies who've used the different kits in the past and the only major comparison/concern between the two is the shifting. The one with the Transgo has said on several occasions that it almost shifts TOO hard if you know what I mean. I know it isn't much, but I hope it helps.
P
p5.0ny
133
Arnold, MO
Jun 17, 2004
  • Jun 17, 2004
If I may make a suggestion. Forget the shift kit and call Dave at JDs Performance. He'll sell you PA's manual VB with a transbrake. Now you're talking performance. I have it, love it and never want to go back to a automatic, automatic again.
89 droptop
86
Centrial California
Jun 17, 2004
  • Jun 17, 2004
How much does that cost for the kit and instalation, also how do you select between 2nd and drive with that kit?
P
p5.0ny
133
Arnold, MO
Jun 17, 2004
  • Jun 17, 2004
You can use the stock shifter, only the following applies:
P = park
R = reverse
N = Neutral
OD = 3rd
D = 2nd
1 = 1st
You must manually shift up from 1st to 2nd to 3rd and down shift manually. Essentially it is a stick w/o a clutch. OD is controlled by a toggle switch and is electronically activated by you while in 3rd gear.
The transbrake works by applying reverse while at a standing stop and in 1st gear. mash the throttle and the tranny will flash to your convertor stall speed, release reverse by way of the 2nd toggle switch and hold on. With a transbrake your foot is never off of full throttle. A T-5 or any other stick can't touch it from a dead stop. And with the right convertor, you'll be walking sticks all day long.
P
p5.0ny
133
Arnold, MO
Jun 17, 2004
  • Jun 17, 2004
Forgot about the price. I bought mine for about $350. I think the price has increased. Installation would be an hour or two at going shop rates. It is a easy install, disconnect the TV cable, drain the fluid, drop the pan, drop the VB, install new VB, mount toggles and tap into a electrical source, have fun.
89 droptop
86
Centrial California
Jun 18, 2004
  • Jun 18, 2004
Wow that sounds awsome I had no idea, I thought us 5.0 guys were stuck with the 1-D-1 shuffle. That is defenetly something I will look into in the future.
O
TransGo shift kit question?
  • optionizerSS
  • Jul 5, 2023
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 7, 2023
AeroCoupe
AOD Shifting Very Late
  • 91StangGT5.0
  • May 21, 2011
12K
Fox 5.0 Mustang Tech May 22, 2011
91StangGT5.0
00" Jmod vs. Transgo Shift Kit help
  • quique
  • Jun 28, 2011
  • SN95 V6 Mustang Tech
4K
SN95 V6 Mustang Tech Jun 28, 2011
quique
G
New AOD, having problems shifting, TV pressure issue..
  • Gen414
  • Jun 28, 2011
36K
Fox 5.0 Mustang Tech Oct 28, 2011
Gen414
G
AOD combo advice?
  • 5LiterCOOP
  • Feb 3, 2011
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 3, 2011
5LiterCOOP
