Transmission Extension Housing Bushing/seal Replacement
AlohaStang1
15
Hawaii
As per the title, I need to replace the bushing and seal of my 94 GT (AODE transmission). Does anyone know of a write-up or video that would help guide me through the process? I plan on doing this with the trans in the car. Thanks.
I don't know if there is a write up for it but I'm sure you could Google it and find a video.
Should be able to just remove the driveshaft, remove cross member and trans mount. Remove the speed sensor and take the bolts out of the tail housing. Knock the bushing and seal out and replace with new. Pay attention to the alignment of the bushing because it has a drain back hole in it. There are tools out there to change the bushing without removing the tail shaft but it's not necessary unless you want to do a lot of them.
You will also need a tail housing gasket.
