Nah, I think you should do it yourself.
You drop the transmission pan to drain the fluid, there is no drain plug. The exhaust pipes are very close there so wait a while for them to cool a bit.
You will possibly find a weird plug in the pan, this is from the assembly line and can be discarded. If you find this plug it means you are the first to drop the pan.
No gasket is required on the pan.
If you want to get fancy, remove the drain plug from the TC and drain that as well.
Replace the filter.
At 61k you absolutely need to change the fluid.
Get your transmission fluid from the Ford Parts Counter.
