My car started howling like the throw out bearing was going out. Since then... I have put 2 clutches and 3 throw out bearings in in the past 2 weeks. I also replaced the pilot bushing, cable, fork, and quadrant...turned the flywheel too. The car is still roaring real bad. The longer it runs.. the worse the sound gets. The louder the sound gets, the harder it is to put the transmission in gear. It does not grind going into gear, but I do have to force it in gear and it holds the gear while driving. If the car is shut off, the transmission shifts fine
The only other thing that turns when the car is sitting still is the input shaft. Has anyone else ever experienced this?
