I seen recommendations posted for Mercon III ATF for use in OEM T-5.Dexron-Mercon ATF. Find a new mechanic.
Question: Why is ATF better than MTF for a 5 speed?
There is no such thing as "Manual transmission fluid"
Automatic trans fluid is not really just for automatics. Many manual transmissions use it, as well as using it in power steering.
Other fluids manuals can use are motor oil or gear oil.
All depends on the trans design. But the T-5 is designed to use ATF
Royal Purple Synchromax Manual Transmission Fluid
This is what I bought not too long ago for my car. But if ATF is better, I'll be switching to it once I get the engine and trans out this coming week. WOOOO SPRING BREAK!
