Transmission or Shifter?
savegoodautonfg
1,085
I just got a new rebuilt transmission about 2 days ago and before i got the new transmission my car would drop out of 2nd gear and a bunch of other problems. since i got the car back with the new rebuilt transmission it stills drops out of 2nd but everything else is great. the place that installs all my **** on my car told me i need to get a new shifter??
Please help..
If you are still having the same problem and you have already replaced the transmission, than that really only leaves the shifter as a possible cause.
2nd gear 'pops' when it doesn't fully engage the teeth.
If your shifter is aftermarket, make sure that your stops are adjusted properly.
Are you saying that you have to grind the gear to get it to stay in 2nd?
If the gear is popping out and you have already replaced the transmission, it must be your shifter...!
I will bring the shifter down to 2nd gear and it will do 2 things..
Either slip out
or pop-out.
What would causes a shifter to do this?
All my other gears are stay in and work perfectly
Try the clutch cable. You may need to get a adjustable one due to the fact that the old cable isnt letting the gear go through all the way. Also check under the car to see if the trans is bolted up snug to the bell housing.
