Transmission problems....again
  • Thread starter Thread starter steel1212
  • Start date Start date Jun 8, 2005
steel1212
1,180
Frankfort, Ky
Jun 8, 2005
  • Jun 8, 2005
We'll I busted my butt and got the t-5 I just got in there day in tonight. I put a new steel bearing retainer on, as well as my short throw shifter, filled it up with royal purple and went for a test drive and there is this aweful wurring sound. Its real loud in all gears except 4th but still can hear it in 4th. My buddy says that the bearing and race may be bad and when we put the new steel retainer on it disturbed them and caused them to make a noise? Any opinions? I'm getting real tired of getting burned on these damn things. I guess my next one will be new
302 coupe
1,952
Macon, Ga.
Jun 9, 2005
  • Jun 9, 2005
it might be related to the steel retainer. Sometimes the bearing race is located in the wrong spot and when the retainer is torqued to spec, it puts to much load on the bearing. There are shims available so that you can space it out a little to get proper preload on the bearing while still getting the bolts torqued to spec.
BigDaddyCee
1,404
Canada
Jun 9, 2005
  • Jun 9, 2005
I also have an 88GT with a T-5. I'm not sure what all was replaced on your tranny/clutch? I redid my clutch last spring. I don't like going back in to redo things so I did a complete over haul. Which included - resurface flywheel, new pilot bearing, new throw-out bearing, new pressure plate, clutch disk, pivot bolt, bearing retainer and clutch fork. Basically anything that can wear out or bent needs to be replaced. Sounds like it is a moving part like a bearing what about your pilot bearing is it smoked? Was everthing properly lubed. Bearing retainers are known to get a groove/ridge in them which makes the throw out bearing stick. Inspect yours by running your fingers over it to see if there is a noticeable ridge? If you didn't replace the throw-out bearing with the new bearing retainer I think that may be part of your problem?
steel1212
1,180
Frankfort, Ky
Jun 9, 2005
  • Jun 9, 2005
The old retainer had a shim in it so I moved it to the new one like the fordmuscle article said to do.
I did not think of the throw out bearing getting a ridge in it...I'll check as I'll have to pull the tranny anyway.
Hey 302, at least its a v8 tranny this time
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jun 9, 2005
  • Jun 9, 2005
In theory the steel retainer should bolt on no prob, but often they dont. I got one from Summit that was so loose I could wobble the input shaft even with the old shim. I just pawned it on ebay because a shim kit is like $60 and the retainer was 40. That and I'm selling the car. You need to check the runout on the input.
steel1212
1,180
Frankfort, Ky
Jun 9, 2005
  • Jun 9, 2005
the new retainer was tight, not remotely loose.
65ShelbyClone
4,675
38
119
Jun 9, 2005
  • Jun 9, 2005
Thats what I'm saying; mine was too loose, yours may be too tight.
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
