  • 1994 - 1995 Specific Tech
transmission question
  • Thread starter Thread starter 95CobraMike
  • Start date Start date Sep 18, 2004
First Prev 2 of 2
95CobraMike
1,046
Lima OH
Sep 20, 2004
#21
  • Sep 20, 2004
  • #21
wait, if i am up under there prying with a long wrench, the wheels spin, even with the e-brake on and it in gear, i dont think i can fit under there to pry on it if the wheels are on the ground...maybe i am too strong???
TrueBlue95GT
966
Connecticut
Sep 20, 2004
#22
  • Sep 20, 2004
  • #22
Try putting a long screw driver in the u-joint to hold it in place.
R
rockin_rick
968
Sep 20, 2004
#23
  • Sep 20, 2004
  • #23
Try putting a 12mm wrench on there and smacking it with a hammer.
Rick
95CobraMike
1,046
Lima OH
Sep 20, 2004
#24
  • Sep 20, 2004
  • #24
so i tried putting a 12 mm wrench on there, putting a bar on the end for more torque....i ended up bending my craftsman wrench instead of budging the bolt....that bolt is a tight mofo...i put a 1/2 inch to 3/8ths inch reducer on the 12 mm socket and put it on an impact wrench, i broke the reducer thingy...it twisted it right off...grrrr
HISSIN50
34
129
Sep 20, 2004
#25
  • Sep 20, 2004
  • #25
have you tried some heat? threadlock likes to come off when heated up. a little torch action (very carefully done) can work very well.
good luck.
95CobraMike
1,046
Lima OH
Sep 21, 2004
#26
  • Sep 21, 2004
  • #26
good luck.
that shall be my next move....
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 21, 2004
#27
  • Sep 21, 2004
  • #27
HEat those bad boys up remember heat expands metal and try sraying them down with some pb blaster of WD 40 for a while see if that help and let them dry before you put fire to them. We don't need any bobo's
95CobraMike
1,046
Lima OH
Sep 21, 2004
#28
  • Sep 21, 2004
  • #28
heated it up and she came right out....thanks now comes the bellhousing and other things...yay i am so excited....
95CobraMike
1,046
Lima OH
Sep 22, 2004
#29
  • Sep 22, 2004
  • #29
are the GT and Cobra transmissions in our cars the same? or are the cobra ones beefed up a bit to handle the extra power?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 22, 2004
#30
  • Sep 22, 2004
  • #30
The cobra t5's are beefed up the gears are coated with something for more info check out www.ddperformance.com
HoofnIt
1,175
North Carolina
Sep 22, 2004
#31
  • Sep 22, 2004
  • #31
I was able to take mine out with a 12mm wrench. I'll bet the heat thing will get it done, just be careful as the gas tank is back there. Have you drained the tranny fluid yet? If not, it will puke out once the driveshaft is pulled out.
95CobraMike
1,046
Lima OH
Sep 22, 2004
#32
  • Sep 22, 2004
  • #32
i actually dont plan on taking the drive shaft out...i think i am just going to swap it all...i think it will be easier that way
so putting a gt tranny into a supercharged cobra wouldnt be the smartest move? i am guessing not now...i just dont have the money right now to go buy a higher performance 5 speed to handle the HPs
approx how long would a freshly rebuild t-5 last me in the supered cobra? taking into account that i wouldnt hammer it down every time i took off....only when people think my car is sick and want to race. (hasnt happened yet and i have had the car for a week)
95CobraMike
1,046
Lima OH
Sep 23, 2004
#33
  • Sep 23, 2004
  • #33
welp, it is 3:31 am...5 hours later....and i am done!!! i went ahead and put the freshly rebuilt T-5 in my cobra, i know it isnt built to handle all of that power, but at least it will get me through the rest of this summer/fall and next summer and fall i hope. it wasnt too bad of a job, i took some pictures, i dont know how to post them, but i have some...the cobra runs much better now, no tranny whine. no vibrations in 2nd and 3rd gears, and no grinding and sticking in 4th...and when taking the h-pipe off, i bent the hangers so it no longer rubs on the bottom of the car anymore....so no more exhaust vibs either...we will see how long it will hold up to 360+ rwhp, only time will tell.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 23, 2004
#34
  • Sep 23, 2004
  • #34
Yeah stock t5's ate not to fond of big power. It's somewhat of a hit and miss with these tranny's some will last a long time and others will take a crap as soon as you fart hard enough.
First Prev 2 of 2
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
