Do you want a manual or auto? Drag only car or DD? WIll slicks be used? You will likely have a real sticky clutch, and if slicks are used, the trans becomes the weak point (as opposed to slipping an organic disk, or spinning tires).
All that stuff kind of dictates the route you will likely go.
Good luck.
