transmission questions???
ok when i was looking at transmission i dont think i did enough research.....
i found that the tko trannys are cheaper then if i went with the gforce trans.
even the t-56 trans is cheaper.
now my questions
on a tko trans what do i need to install it?
is the t56 hard to put in what would i need for that?
is the tko trannys stronger than the gforce?
if u guys could tell me this infor so i can figure out if i would be better to go with the tko or the gforce that would be great.
also i planned on getting a new bellhousing bullet proof and aluminum flywheel and spec 2/3 clutch. so let me know what i would need for the tko installs so i can compare prices and such
thanks.
dan
NO way man, going G-force is definitly cheaper than going TKO or T-56. Im in the middle of a TKO swap myself and it came in just under 2,000 bucks.
for a 94-95 TKO-500 swap you need
TKO-500
TKO bellhousing
Short Clutch Fork
31 spline slip yoke
Drive Shaft Spacer
Offset Trans Mount
3 Quarts of GM SyncroMesh
Not sure what exactly you need for the T-56 but i konw D&D sells a kit for 2,500 bucks that should have everything.
hey white devil where did u get the drive shaft spacer?
a couple of other questions?
dd has everything i need for the swap?
will a spec clutch and fendeza aluminum fly wheel work?
our cars are 26 spine stock correct?
where does the driveshaft spacer go?
with that im guessing the drive shaft is too short or does it need to be cut?
with a bullet proof housing i need a longer cluthc fork correct?
thanks
dan
stang_dan said:
the g force i was looking at was 2700 so lol
what id d&d do they have a site
i might go the t56 i always wanted a 6 speed lol.
thanks
dan
Woah man i dont konw what G-froce kit you were loking at. Because the G-force T-5 Helical Cut Syncro Kit is 1095 dollars. Plus the rebuild which still doesnt put it anywhere near 2700 you were looking at the wrong kit thats for damn sure.
thanks
dan
Yeah D&D should have everything you need. You dont need a new flywheel for this swap, but im sure a fedenza would work fine i have a spec 1 clutch. Our cars have 10 spline trannies and clutch disks. If you want a 26 spline tranny you will need to make sure that you buy a 26 spline clutch disk. It goes at the end of the transmission where it meets the rear end. The DS is too short because the tranny input shaft is shorter so the new bellhousing is 5/8 in shorter than you stock one. So you need the spacer to make up for that difference. Im not sure which one you need for the scatter proof housing. I just got the aluminum bell because i dont see much hard core action in my futur since my local drag strip closed, and for that i needed a shorter 86-93 clutch fork.
i just looked again at astro performance and the g force trans was like 2600 with the good options?
the tko was like 1600
with everything the tko comes to like 2700 or so
i am goin to get all that stuff cause im building a347 annd doin everything at once when i get back from iraq
i think im goin to go with the tremec. tko-600
do i need to get a adj clutch cable thing or stock one will work?
let me know how your install goes if ther are any tricks
thanks
dan
thanks
dan
Wow thats a crazy amount of money. I would just buy the kit 1095 and have it built locally for like 500 bucks.
I have a Firewall adjuster and a steeda clutch quadrant but i dont think they are necessary.
Yeah i went with it cause next summer im going with a 347 a well, so i wanted something real strong. My TkO packge came to just under 2000 so i would do some shopiing around cause Astro seems to have some high ass prices.
stang_dan said:
Original tranny palns put me at like 2800 totall if i can get all that for 2 that would be great i might be alittle more for the bullet proof housing tho
where did u get all of your stuff dd
let me know i defently am getting the tko
dan
I actully got my stuff from Tommy Vaugne ford in Houston because i was there on vacation. But D&D has similar prices but i just got it there to save on shipping. Tranny was 1590 i believe. If you go TKO-600 thats 100 bucks more and ithink the scatter proof bell is 100 bucks more, then shipping too. But i would think you could get it all for less than 2500 from D&D.
As for the engine set back im not too sure but it seems like it makes sense that it would aleviate the need for the spacer.
