Transmission strength
This has to have been covered. I have spent the last 45 minutes searching, and i feel like a ****ing retard because i cant find the answer.
What is the limit of the stock T-5.
I just bought an 89 vert. I love drag racing. The rear has an auburn, and 31spline shafts with 5 lugs.
The car has SFC welded in, with a 6 pt cage welded in. the old owner replaced the motor and trans that were in it(it was his race car) with a stock motor out of a 93 SSP with the matching trans. I plan to throw a GT-40 intake, heads, and E cam in it and daily drive it. But it will see the track. Is the trans going to live with clutch dumps and slicks?
The stock trans was the first thing to go in mine. All it took was an NOS stageII kit and slicks. First run was a 13.4 and the second was more than it would take. I am now running mid to low 11s with a Tremec TKO and so far no problems.
Ive done the Madden 2-3 shift myself! Boom! That transmission's gotta be lopsided after that one!
I had a stock longblock 351w with carb retro gear, made 220hp and 305tq at the wheels.
It was a 2.3 turbo tranny. Great gearing, bad strength.
Remember this, a good t5 has some value to it, a broken one is worth $100 or less depending on what you broke.
So if you know you are going to replace it, go easy on it so you can get the most money back out of it.
Something my dumbass didn't do.
So instead of getting $500 for it, i got $100.
Ran through 3 t5's in a stock 90lx with a good tire and some power shifting... haven't had any issues with the few tremecs i've used.. I'd say sell the T5 and go wtih something else while it's still good like others suggested
+1 for killing T5s on the 2-3 shift. I've done it twice in my car, and I'm still not over the 300 hp mark. Did it once with a completely stock engine.
G Forces are good for 4-500 Ft-lb ratings depending on the model you buy. I've rode in a G-Force car before, those things are pretty tough. I want to say that was a 10 second car, but I can't remember now. I thought I heard that G Force trannys are no longer made new, but I can't verify that.
Check out Astroperformance.com - Your Manual Drivetrain Specialist. The T5 I've got in my car now is a "Cobra" spec built by Astro... Good stuff. They are pretty helpful on the phone, kinda have the small-shop personality, but sometimes can be hard to get a hold of. Hopefully they've hired a secretary since. :rolleyes: Anyway, they have some pretty sweet options for T5 builds, and they carry this "A5" line that can handle 650HP.
For an aftermarket tranny, the G-force is the way to go.
The T-5 is lightest of all the Tremec/Borg-Warner designed transmissions. It also shifts the best IMHP and i'm sure many will agree. It's problems have always been strenght and now for the price of a 3550 you can cure that and make it plenty strong. PLUS, it's easy as hell to rebuild a T-5. They are one of the best designed manuals in terms of service.
Pretty much the weakest points to the t-5 are the mainshaft flexing and shearing teeth off 3rd gear. So g-force has a stronger mainshaft and stronger gears (the teeth are beefy as hell). Just those two little changes increases strenght A LOT!
